{SOLVED} Floor Plan on PTP 2.x...
jarane
by jarane » Mon May 12, 2014 11:12 pm
my client is used to the animation and functionality that the default Floor Plan settings had in 1.8.
Is there a preset that can achieve that?
Here's the example:
http://www.extremevr.com/mraf/mraf12.html
Thanks in advance,
E.C.
Re: Floor Plan on PTP 2.x...
by mediavets » Mon May 12, 2014 11:31 pm
jarane wrote:Hi,
Here's the example:
Thanks in advance,
E.C.
You can emulate the behaviour of the PTP 1.8 map extra, using PTP 2.1 to some extent.
You can animate the display of the floorplan - see screenshot for plugin options.
If you also use a Simple button plugin (using a smaller version of the floorplan graphic) to invoke the display of the floorplan and open the floorplan over the top of the button, and allow the floorplan to close on click, then it will look rather like the PTP 1.8 map extra behaviour.
However AFAIK animation of the hotspot representing the current pano is not yet available in PTP 2.1 floorplans.
jarane
by jarane » Mon May 12, 2014 11:40 pm
Thanks, my friend!
Will try that.
E.C.
Users browsing this forum: No registered users and 14 guests
