(SOLVED) Xml code integration...
jarane
by jarane » Sun May 04, 2014 11:38 pm
I'm discovering some of the differences between PTP 2 and 1.8.
I'm trying to include the "sharpness" and "mouse speed" codes to the xml files PTP 2.x creates, and found out that 2.x does not create xml files the same way 1.8 did.
1.8 created 1 xml file per pano and 2.x creates only 4 xml files for my entire 11-pano tour.
I tried adding the code to every one of these 4 files with none of the wanted results happening.
Question:
Which of the PTP 2.x files is the one that will respond to the xml codes?
Exactly where in the document should the code be added?
Also, Is there a tutorial on how to create themes (or how to change the icons in the control bar) for PTP 2.x?
Thanks in advance,
E.C.
Re: Xml code integration...
by mediavets » Mon May 05, 2014 8:33 am
jarane wrote:Also, Is there a tutorial on how to create themes (or how to change the icons in the control bar) for PTP 2.x?
Thanks in advance,
E.C.
Check out Advanced notions in the PTP documentation:
http://www.autopano.net/wiki-en/action/ ... umentation
Likes: 14 posts
by bdd » Mon May 05, 2014 11:50 am
jarane wrote:Which of the PTP 2.x files is the one that will respond to the xml codes?
All the generated XML files.
jarane wrote:Exactly where in the document should the code be added?
It depends on which code you add.
If you add a scene specific code, it should be in the main XML file.
If you add a tour specific code, you can add it in any of the generated XML files.
jarane
by jarane » Mon May 05, 2014 2:03 pm
Got it!
Thanks, guys!
E.C.
