Aaron Eriksson wrote:I don't mean to be negative but I am frustrated. I pulled in both the Website box plugin and the video plugin, in the effort to display a full size youtube video. The moment I try to set the hotspot button of a video camer icon the project crashes.
Folks. Please get this program fixed. Overall it is great but there are still basic bugs that have not been resolved. Especially the program not keeping the cursor in the point of view settings.
So how can I display a video for a site using the GUII and not coding it in?
Aaron Eriksson wrote:Right. So I am using a custom graphic as the link. the steps I am taking.
1 import the icon into my library.
2. under the style tab, and viewers tab I activate either the webvideo box plub in or the website viewer box plug in.
Fine so far no crashing.
Then I take the actions on the graphic to activate the respective plugin. That is the moment it crashes. The only way it doesn't crash is when I use a basic "open a website" action which is NOT what I want to do. I used to be able to do this, but now can't. I do have the latest updated version.
Aaron Eriksson wrote:Right I just tried your shots. Crashed.
Aaron Eriksson wrote:Do you want to see my screen? I can do a join.me for you.
Aaron Eriksson wrote:Windows 8.1 home
PTP 2.0.1
Yes it is a tour fresh with latest version. Previous version did the same.
Aaron Eriksson wrote:No Problem. I know you volunteer. But I need a tech to email me back or help me get through this asap. Do you know if there is a ticket I can report?
