Button to hide only Infopoints
frank007
Likes: 12 posts
by frank007 » Tue Apr 22, 2014 1:25 pm
Hello from Germany,
in a very big tour I have two kinds of hotspots. 1. hotspots to go to the next pano. 2. hotspots to link to a webpage.
Is it possible to integrate a button that hides/shows only the hotspots linking to the webpages? I have found only the oppurtunity to hide or show ALL (!) hotspots.
Thank you!
Greetings
Frank
Re: Button to hide only Infopoints
by mediavets » Tue Apr 22, 2014 1:34 pm
frank007 wrote:Hello from Germany,
Thank you!
Greetings
Frank
There's no way via the GUI.
If the tour is a linear sequence of scenes, you could consider using one of the Previous/Next plugins to navigate between scenes rather than hotspots. that would then mean you only had hostpost linking to web pages left to hide/show.
frank007
Likes: 12 posts
by frank007 » Tue Apr 22, 2014 1:37 pm
Uhhh... that is bad. But I thought already that it might be not possible.
thanky
franky
Likes: 13 posts
Liked in: 115 posts
by bdd » Wed Apr 23, 2014 10:05 am
Thank you!
Greetings
Frank
Is is not possible through the GUI, but you can do it quite easily by modifying the generated code.
If you look into the main XML file, you'll see that in each scene there are "showpanospotsaction" and "hidepanospotsaction" actions.
You can either modify those actions, or duplicate them and show and hide only the wanted spots.
