Flat or Partial Pano
Aaron Eriksson
by Aaron Eriksson » Mon Apr 21, 2014 2:35 am
I have a partial pano. I know the settings are different from a full pano. How do you import and set the FOV? Do you folks have a tutorial?
Re: Flat or Partial Pano
by mediavets » Mon Apr 21, 2014 9:15 am
Aaron Eriksson wrote:I have a partial pano. I know the settings are different from a full pano. How do you import and set the FOV? Do you folks have a tutorial?
Partial panos created with APP/APG will have a custom Kolor EXIF tag which records - among other things - the H and V FOV and vertical offset. These values may be viewed using any EXIF reader; see screenshot below.
If the rendered pano has not been processed before input to PTP in such a way that destroys this EXIF tag then PT/PTP will read the EXIF tag and set Input FOV and vertical offset accordingly.
If for whatever reason this EXIF tag data is missing you will have to set Input FOV and vertical offset data manually. PT/PTP will attempt to estimate these FOV values based on the aspect ratio of the image but, of course, this estimate will usually be incorrect.
If you wish to use a conventional (non-pano) image in a tour then simply change the projection type to planar.
Aaron Eriksson
by Aaron Eriksson » Mon Apr 21, 2014 1:59 pm
Thanks for the detailed response.
Users browsing this forum: No registered users and 8 guests
