Video is too small on iPad
toto-foto
by toto-foto » Fri Apr 18, 2014 7:46 pm
Video opens in very small frame on iPad.
And it does not depend on the initial size of video mp4 file. There is a black .jpeg file in spots folder, which should define the size of video-frame, but if to resize it up to 960x540 px, it doesn't couse any changes...
How can I increase video size on iPad or to force it to start in full screen mode?
http://virt-tour.ru/pano/tem19-ptp2a/tem19.html
Anton
Likes: 13 posts
Liked in: 118 posts
Re: Video is too small on iPad
by bdd » Wed Apr 23, 2014 8:40 am
toto-foto wrote:Video opens in very small frame on iPad.
Anton
You can edit the tem19_skin.xml file.
At line 1177, you'll see the following :
      set(layer[displayedStandardVideo].align   , %2);
      set(layer[displayedStandardVideo].x       , %3);
      set(layer[displayedStandardVideo].y       , %4);
      set(layer[displayedStandardVideo].width   , %5);
      set(layer[displayedStandardVideo].height  , %6);
Change it by the following :
    if (device.desktop,
      set(layer[displayedStandardVideo].align   , center);
      set(layer[displayedStandardVideo].x       , 0);
      set(layer[displayedStandardVideo].y       , 0);
      set(layer[displayedStandardVideo].width   , 100%);
      set(layer[displayedStandardVideo].height  , 100%);
toto-foto
by toto-foto » Wed Apr 23, 2014 9:35 am
Thank you very much, bdd!
Now it opens in full frame on iPad :)
But there is another problem bothering me: additional pressing PLAY button is needed now to start video... Can I get rid of Play button on iPad/iPhone? And video does not close automatically on iPhone after tapping on it :( I've to wait while it's playing to the end. In old versions i could press "rewind" and then "Done" to close the video, now nothing helps to close it prematurely on iPhone...
PTP1.8 tour: http://virt-tour.ru/pano/kolomna1v6/tem19.html
PTP2.1 tour: http://virt-tour.ru/pano/tem19-ptp2a/tem19.html
The attachment video.jpg is no longer available
Anton
    if (device.desktop,
