Map opened when group is displayed
aircamera
by aircamera » Thu Apr 17, 2014 1:01 pm
Hi !
That would be great to have an option to activate one precise map when one group is displayed. So it could automaticaly change when group is changing... =D
Re: Map opened when group is displayed
by mediavets » Thu Apr 17, 2014 1:44 pm
aircamera wrote:Hi !
Are we talking about Panotour maps plugin or the Floorplan plugin?
You can add a map point for a Group:
aircamera
by aircamera » Sat Apr 19, 2014 2:43 pm
mediavets wrote:Are we talking about Panotour maps plugin or the Floorplan plugin?
We are talking about the Floorplan plugin. And it already works as I wished. I was simply not using enough groups to work correctly. Floorplan plugin is great ! =D Thank you
aircamera
by aircamera » Fri Aug 29, 2014 9:26 am
Is it possible to open automatically floor plan when a group is displayed, and to close it automatically when this group is closed ?
by mediavets » Fri Aug 29, 2014 9:32 am
aircamera wrote:Is it possible to open automatically floor plan when a group is displayed, and to close it automatically when this group is closed ?
As I recall the floorplan will change to match the group to which currently displayed pano belongs, b8t perhaps that's not what you seek to achieve?
aircamera
by aircamera » Fri Aug 29, 2014 9:48 am
Indeed.
But I would like this plan to disapear completly from my screen if I change the group. At the moment, when I get away from one group, this floorplan stays on even on an aerial view for example.
I would like it auto on inside, and auto off outside...
by benji33 » Wed Sep 03, 2014 2:03 pm
Already added as a feature request for a future release.
