360 video in iframe on Panotour pro 2.0
UVU360
Likes: 4 posts
by UVU360 » Thu Apr 10, 2014 3:48 am
Not sure if this makes sense but could I theoretically post a finished 360 video to your kolor.eyes hosting site then copy the iframe address into a panotour pro 2.0 project? example is I am looking around a stitched still frame of a bedroom and put a hot spot on a tv set in the room. when clicked it would bring up the iframe window and play the video but not completely leave the virtual tour enviroment to go to another page?
Likes: 3 posts
Liked in: 226 posts
Re: 360 video in iframe on Panotour pro 2.0
by Destiny » Thu Apr 10, 2014 3:58 am
Hi.. If you are using PTP do view your 360 video, you do not need an iframe.. Just add the 360 video to a html and then add a website box into PTP project and done.. Resize your website box accordingly.. You just need to provide the full url to the host address..
If you need me to test it for you and send you a PTP file I will do this for you.. Just send me the url to your 360 video via my PM...
by mediavets » Thu Apr 10, 2014 9:33 am
Destiny wrote:Hi.. If you are using PTP do view your 360 video, you do not need an iframe.. Just add the 360 video to a html and then add a website box into PTP project and done.. Resize your website box accordingly.. You just need to provide the full url to the host address..
You can find the gallery of 360 videos and embed coding here:
http://www.kolor.com/360-video/gallery
Likes: 3 posts
Liked in: 226 posts
by Destiny » Thu Apr 10, 2014 10:21 am
:/ Now I understand the need for an iframe..
So I am guessing you need something like this...
http://www.destinyvirtualtours.com/PTPV ... oTest.html
Likes: 11 posts
Liked in: 96 posts
by bdd » Thu Apr 10, 2014 1:42 pm
UVU360 wrote:Not sure if this makes sense but could I theoretically post a finished 360 video to your kolor.eyes hosting site then copy the iframe address into a panotour pro 2.0 project? example is I am looking around a stitched still frame of a bedroom and put a hot spot on a tv set in the room. when clicked it would bring up the iframe window and play the video but not completely leave the virtual tour enviroment to go to another page?
You just have to use a Web Video box. and display it with the URL of your 360 video hosted on eyes.kolor.com
UVU360
Likes: 4 posts
by UVU360 » Thu Apr 10, 2014 2:06 pm
Destiny wrote::/ Now I understand the need for an iframe..
Hi Destiny. Yes you nailed it. :)
How?
Likes: 3 posts
Liked in: 226 posts
by Destiny » Thu Apr 10, 2014 11:02 pm
Hi... You can do what Gérald said to display your video which I have not tried but might be the better way to go, or I did this.. Copy the iframe url I am assuming is generated, and then copy that into a bank html page as below.. Save as index.html or video1.html etc then up lost that to your web host. Add a Website Box to your Tour and size accordingly. Add a hotspot or a button and then add the url to that.. You can add a title and a custom hotspot.. This is all Kolor media so should work on any device...
Done... =D
<iframe src="http://eyes.kolor.com/fr/i/5e936abfc36f423ba96f3447d5774d7b" mce_src="http://eyes.kolor.com/fr/i/5e936abfc36f423ba96f3447d5774d7b" type='text/html' width='800' height='600' frameborder='0' scrolling='no' allowfullscreen='true'> </iframe>
UVU360
Likes: 4 posts
by UVU360 » Fri Apr 11, 2014 4:37 am
Thanks again Destiny, and all who responded. I am new to this and doing the tutorials in Kolor. I appreciate your time and will try to make it work with your instructions.
Best
Tim
