[SOLVED] Vertical planar projection zoom out problem   [SOLVED] - View the solution
tcrutch
by tcrutch » Thu Apr 10, 2014 2:01 am
Is there anyway to set the minimum height of a planar panorama's zoom through Panotour pro 2.0? I am having difficulties zooming completely out to see my entire image. It seems that the panorama height is dictated by the browser width (example in the link below).
http://scci.csumain.csu.edu.au/tcrutche ... build.html
Am I missing something really simple? I know I am doing something a little different by documenting Egyptian Khayamiya, but I thought there'd possibly be a simple solution. Help would be very much appreciated.
Likes: 786 posts
Liked in: 431 posts
Re: Vertical planar projection web problems  [SOLVED]
by Annis » Thu Apr 10, 2014 8:58 am
If you want to be able to zoom out your planar image completely, you will have to make a minor edit to the .xml (in the future Panotour should hopefully give you this option directly) but until then, here is what to do:
Open the YOURTOUR.xml file, find the name of your scene (=the name of your panorama) and search for limitview="range" and edit range into fullrange (see screenshot).
tcrutch
by tcrutch » Thu Apr 10, 2014 11:36 pm
Thankyou so much Annis!
