Buttons only on iphone, ipad, tablets etc...
joshfifty
by joshfifty » Wed Apr 09, 2014 2:27 pm
I'm using the gyro option so only need the button on hand held devices, was wondering if it's possible to set a button to only appear on certain devices? I'm gonna assume if possible then it will be in the .xml
Re: Buttons only on iphone, ipad, tablets etc...
by mediavets » Wed Apr 09, 2014 2:44 pm
joshfifty wrote:I'm using the gyro option so only need the button on hand held devices, was wondering if it's possible to set a button to only appear on certain devices? I'm gonna assume if possible then it will be in the .xml
By default tours created with PTP only display relevant/appropriate control bar buttons/icons depending on teh type of platform used to view the tour.
Most control bar buttons/icons are not displayed on multitouch UI devices.
Likewise the Gyroscope button/icon is not displayed in control bars on devices that don't support the gyroscope function.
joshfifty
by joshfifty » Wed Apr 09, 2014 3:39 pm
Ah right thanks!
