[SOLVED] I want more buttons!
ImagoFactory
by ImagoFactory » Tue Apr 08, 2014 10:33 pm
Hi all, I just want to build a tour; a simple one; 3 panoramas, 1 small photo gallery and 1 description.
All was ok until I tried to put some buttons; 2 worked fine, but each time I put the third, one of the other 2 disappeared!
I tried for 2 days and now I got tired :(
Is it me or there is a button limitation?
This is the link but, of course, you will see only 2 buttons :)
http://www.imagofactory.ro/demo/bisarmd ... mdemo.html
Please help me!
Thank you in advance for your answers.
Re: I want more buttons!
by mediavets » Tue Apr 08, 2014 10:46 pm
ImagoFactory wrote:Hi all, I just want to build a tour; a simple one; 3 panoramas, 1 small photo gallery and 1 description.
Please help me!
Where are the buttons?:
by klausesser » Tue Apr 08, 2014 10:50 pm
ImagoFactory wrote:Is it me or there is a button limitation?
No. There is no button-limitation. But compared to PTP 1.8 the handling of PTP2.0 is very inconvenient.
Did you look into the "tutorial"?
PS: i also don´t see any button!
ImagoFactory
by ImagoFactory » Tue Apr 08, 2014 10:59 pm
I used png images for the buttons. They are top left and bottom right;("Actul de fondatie" and "Galerie imagini") I don't think that where they are is important, but the fact that I cannot add one more.
by mediavets » Tue Apr 08, 2014 11:26 pm
ImagoFactory wrote:I used png images for the buttons. They are top left and bottom right;("Actul de fondatie" and "Galerie imagini") I don't think that where they are is important, but the fact that I cannot add one more.
Are these two instances of the Simple button plugin? Or some other plugin?
Can you show us a screenshot of the the plugin settings for each button?
ImagoFactory
by ImagoFactory » Tue Apr 08, 2014 11:30 pm
Simple buttons
ImagoFactory
by ImagoFactory » Tue Apr 08, 2014 11:31 pm
right now
ImagoFactory
by ImagoFactory » Tue Apr 08, 2014 11:37 pm
As a matter of fact, these 2 buttons work fine; it's the 3rd that has no place and makes the 2nd disappear.
by mediavets » Tue Apr 08, 2014 11:49 pm
ImagoFactory wrote:As a matter of fact, these 2 buttons work fine; it's the 3rd that has no place and makes the 2nd disappear.
Is it possible that two of the buttons are in the same location - on top of each other?
I was able to create four buttons with no problem.
ImagoFactory
by ImagoFactory » Tue Apr 08, 2014 11:54 pm
in 2 days I changed a lot the positions to avoid such a situation, even so, being png's, they can be seen.
this is an answer I got on Panoramic Photographers: Xander Berkenhagen I had the same problem. Your project file has been corrupted. Don't know how but apperently it happens more often. Think its a bug in 2.0.1. If you send them your project file they can fix it.
What is your opinion?
by mediavets » Wed Apr 09, 2014 10:01 am
ImagoFactory wrote:in 2 days I changed a lot the positions to avoid such a situation, even so, being png's, they can be seen.
That has not happened to me.
But in such situations it's always worth trying Building to a new folder to force a complete re-build.
ImagoFactory
Re: (SOLVED) I want more buttons!
by ImagoFactory » Wed Apr 09, 2014 10:07 am
Thanks, I'll try that too; meanwhile Gerald fixed it for me and I'll see how it works.
mattkay
Re: [SOLVED] I want more buttons!
by mattkay » Sun Apr 20, 2014 2:33 pm
I had the same problem. 2 buttons and no more. You could add an additional button by adding a Logo and using this as a button.
yvano
by yvano » Tue Apr 22, 2014 12:44 pm
I had the same problem, and Gerald told me that this problem will be fixed with the 2.0.2 which should be soon available....
The other solution is to create a new tour
by mediavets » Tue Apr 22, 2014 1:19 pm
yvano wrote:I had the same problem, and Gerald told me that this problem will be fixed with the 2.0.2 which should be soon available....
2.1 RC1 is already available.
yvano
by yvano » Tue Apr 22, 2014 1:41 pm
I didn't know about the RC1, so the problem should be fixed with this version....
I gonna try and tell you....
