License problem with mobile device
KlausFuchshuber
by KlausFuchshuber » Mon Apr 07, 2014 3:53 pm
my Tour (made by PTP 2.0) works on desktop browser very good.
But when i try to look to the tour with my iPhone / iPad - i get a license error.
Here is the url:
http://mw.aldiana.ds360grad.com/rundgan ... kreta.html
I have insert the domain ds360grad.com in the security part of the software - but it doesn't work.
Do you have any ideas why?
Thanks!
Re: License problem with mobile device
by mediavets » Mon Apr 07, 2014 5:10 pm
KlausFuchshuber wrote:Hello,
Here is the url:
Thanks!
Does it work if you have no domain specified?
Which version of PTP did you use to create this tour? The page source suggests that it was PTP 2.0 beta 1, if correct that version if well out of date.
Are you using a custom HTML template?
Did you create both desktop and mobile versions of the tour?
KlausFuchshuber
by KlausFuchshuber » Tue Apr 08, 2014 8:09 am
Here is the url:
Thanks!
I have not tried yet
I made the tour with 2.0 beta 1
no
yes
Thank you - i will try these changes - if it doesnt work then i will be back!
