Floorplan where is it   [SOLVED] - View the solution
Liked in: 6 posts
by ccc23444 » Sun Apr 06, 2014 10:21 am
Hi all
Juggled around with floorplan.
I know that now I have it in the toolbar.
But I'd like to have a small icon in the corner, like in ver 1.8 . Is that possible?
Best regards
Jesper Frehr
Likes: 3 posts
Liked in: 226 posts
Re: Floorplan where is it  [SOLVED]
by Destiny » Sun Apr 06, 2014 12:23 pm
Hi Jesper
You can add a button of any graphic you like, then link the floor plan to it in the actions... It will be Tour specific since their is no pano specific option within the UI so if you need a button/icon for other floor plans to use for individual panos you will need to had code the xml...
Users browsing this forum: No registered users and 9 guests
