shop360 wrote:i've been having the same problem with borders not being applied correctly (masking zone) haven't been able to make it fit properly..
i think it has something to do with the fact that even if you use the same lens, the video you shoot is slightly cropped compared to the still pictures so when overlaying and stitching it, it's not a perfect fit
Kolor?
ygilquin wrote:When using blur gradient on mask, you must assure your mask is inside the image enough to prevent the gradient from being cut by image boundaries, else such a straight line would appear.
ygilquin wrote:Can you please share your files with us to allow a deeper investigation ? Sharing process is described here http://www.kolor.com/forum/viewtopic.php?f=3&t=766
Please upload your .pano + video file (only keep a few seconds if possible) + video snapshot + all image files
