Radar of active spot
marbotrade
by marbotrade » Fri Apr 04, 2014 12:37 pm
Well, well, well, the Version 2.xxxx it is like a new language.
Must go and search where the function are fit...
So, does anybody know where is the radar of active spot?
I think that in version 2, they use chinesse workers..
Re: Radar of active spot
by mediavets » Fri Apr 04, 2014 1:18 pm
marbotrade wrote:Well, well, well, the Version 2.xxxx it is like a new language.
Do you mean where in in the XML code files or where in the GUI?
marbotrade
by marbotrade » Fri Apr 04, 2014 1:44 pm
in 1.8 have radar for a spot...here....in 2.xxxxxxx, none
by mediavets » Fri Apr 04, 2014 2:27 pm
marbotrade wrote:in 1.8 have radar for a spot...here....in 2.xxxxxxx, none
See:
marbotrade
by marbotrade » Fri Apr 04, 2014 3:50 pm
In win 32 don't works. This Plugins....are zero. Do nothing.
by mediavets » Fri Apr 04, 2014 5:19 pm
marbotrade wrote:In win 32 don't works. This Plugins....are zero. Do nothing.
Are you viewing the tour locally or online?
If locally then use the View last built tour.. button in order for all features to work correctly.
See: http://www.autopano.net/wiki-en/action/ ... ur_locally
marbotrade
by marbotrade » Fri Apr 04, 2014 7:09 pm
Thank you, I founded too, that only locally don't works.
But must say this...to all that test the application..not try see that don't work...and..
