upload issues
georgess
upload issues
by georgess » Fri Apr 04, 2014 12:28 pm
Hello again guys. My issue at the moment is I managed to upload the folders generated after a build (via file zilla) and created a url, however, when I upload the data folder and .html of another build I keep getting a message that some items already exist. I am then asked to rename these items which messes things up a bit. Basically the first upload works perfectly, anything after that has issues.
Any ideas on this?
Regards,
George
Re: upload issues
by mediavets » Fri Apr 04, 2014 1:17 pm
georgess wrote:Hello again guys. My issue at the moment is I managed to upload the folders generated after a build (via file zilla) and created a url, however, when I upload the data folder and .html of another build I keep getting a message that some items already exist. I am then asked to rename these items which messes things up a bit. Basically the first upload works perfectly, anything after that has issues.
Any ideas on this?
Regards,
George
Does Filezilla not have an option to overwrite existing files and folders of the same name?
georgess
Re: upload issues
by georgess » Fri Apr 04, 2014 1:41 pm
strangely enough I'm no longer getting the pop up that allows me to choose over right, just a small window appears asking me to rename certain images. strange
georgess
Re: upload issues
by georgess » Fri Apr 04, 2014 8:05 pm
Right, so I'm now getting these grey bits in my tours. This I think is down to file Zilla. Image attached, anyone had this kind of thing before?
pano-capture.tiff
Re: upload issues
by mediavets » Fri Apr 04, 2014 8:34 pm
georgess wrote:Right, so I'm now getting these grey bits in my tours. This I think is down to file Zilla. Image attached, anyone had this kind of thing before?
Can we view the online tour?
georgess
Re: upload issues
by georgess » Fri Apr 04, 2014 10:23 pm
I re-uploaded to another server and no issues so it's down to the server. I'll be having a word :-)
