XML Papywizard to assist in stitching a LivePano pano
Liked in: 226 posts
by Destiny » Fri Apr 04, 2014 10:38 am
Hi...
Is it posible to use Papywizard XML file to assist in stitching a pano which will be used for LivePano...
Here I imported my pano images, and the single frame and its all good... I then exported the Papywizard XML but when I import my XML using Papywizard, the results are not good... There may be an occasion where there are a lot of featureless areas within the LivePano....
