[Solved] Can't dislpay the floor image
marbotrade
by marbotrade » Fri Apr 04, 2014 10:29 am
Two groups:two floor image.
Are not show/hide...about giroscope on floor....eheeee...another strory....
P2.0
Re: Can't dislpay the floor image
by mediavets » Fri Apr 04, 2014 1:22 pm
marbotrade wrote:Two groups:two floor image.
Did you add the Floorplan plugin in the Style/Workspace and configure it appropriately?
Did you add a control to your Control bar to show/hide the floorplan?
about giroscope on floor....eheeee...another story....
What about 'gyroscope on the floor'? Whatever that may mean.
marbotrade
by marbotrade » Fri Apr 04, 2014 1:41 pm
"add the Floorplan plugin"....from where must Add?
"about giroscope on floor....eheeee...another story."
=a radar for a spot
by mediavets » Fri Apr 04, 2014 2:29 pm
marbotrade wrote:"add the Floorplan plugin"....from where must Add?
=a radar for a spot
See:
marbotrade
by marbotrade » Fri Apr 04, 2014 3:49 pm
Thank you.
First of all: the resolution on screen must be more 1024x 768....because in this case not all the buttons are see in screen....it is a bug of kolor.
2.
In win 32 see what you send me - screen capture, but when realize the VT....are not display - I used of course the show/hide floorpane buttons.
So, in my opinion are many bugs version2 for win 32.
by mediavets » Fri Apr 04, 2014 5:19 pm
marbotrade wrote:Thank you.
2.
OK - are you viewing the tour locally or online?
If locally then use the View last built tour.. button in order for all features to work correctly.
See: http://www.autopano.net/wiki-en/action/ ... ur_locally
marbotrade
by marbotrade » Fri Apr 04, 2014 7:19 pm
Yes it is right. Only online works fine.
KOLOR must tell about this..
marbotrade
by marbotrade » Sat Apr 05, 2014 5:54 am
Mongoose - contain a virus!
Emsi Software block them!
Users browsing this forum: No registered users and 8 guests
