Animated Map Spot
vickywrig
Animated Map Spot
by vickywrig » Thu Apr 03, 2014 11:37 am
Please, does anyone know if an animated spot exists in PTP2 for the floorplan. I want the current location in the tour to be highlighted on the floorplan when it is revealed and hidden. I know the obvious option is radar but that is not stable/does not appear on my output platform. Just want a spot that flashes, this would be great! Thanks =D
Re: Animated Map Spot
by mediavets » Thu Apr 03, 2014 12:20 pm
vickywrig wrote: I know the obvious option is radar but that is not stable/does not appear on my output platform.
Which output platform is that?
by mediavets » Thu Apr 03, 2014 12:25 pm
vickywrig wrote:Please, does anyone know if an animated spot exists in PTP2 for the floorplan. I want the current location in the tour to be highlighted on the floorplan when it is revealed and hidden. Just want a spot that flashes, this would be great! Thanks =D
Not currently available via the GUI AFAIK.
vickywrig
by vickywrig » Thu Apr 03, 2014 2:12 pm
"GUI AFAIK" pardon. What is that in simple terms?
You won't like my answer mediavets, as quite rightly you believe PTP2 is not designed for this, but output is an offline exe. It just has to be that way. Thanks
by klausesser » Thu Apr 03, 2014 3:44 pm
GUI = GraphicUserInterface. That means: it´s the window in which you do your work. This is a kind of interface to the code-based structure which is the nature of any application.
I think Andrew means that you need to edit in the XML code instead of editing it in the "wysiwyg" (what-you-see-is-what-you-get) editor.
AFAIK = As Far As I Know ;-)
by mediavets » Thu Apr 03, 2014 6:53 pm
vickywrig wrote:You won't like my answer mediavets, as quite rightly you believe PTP2 is not designed for this, but output is an offline exe. It just has to be that way. Thanks
Does the floorplan work at all in your offline EXE version?
How are you creating the EXE?
Liked in: 226 posts
by Destiny » Fri Apr 04, 2014 1:22 am
Hi..
No animated map spots availabe... I asked for them a long time ago... Perhaps there is a reason why since the map spots have their own group...
vickywrig
by vickywrig » Fri Apr 04, 2014 2:48 pm
The floor plan does work in each of the exe. platforms that I'm using, with variations.
Server2go - Floorplan with hotspots that navigate - but no radar.
Autoplay (used as a front end title page) - Floorplan works but upset by radar, would animated hotspot do the same?
HTML Executable - Both work but prefer output from autoplay because the tour remains within the same interface.
Sorry for baffle.......
Liked in: 226 posts
by Destiny » Sat Apr 05, 2014 8:23 am
Have you tried the krpano server. Everything works as far as I know..
