Direction buttons works locally but not online
gabriel
Likes: 14 posts
Liked in: 11 posts
by gabriel » Wed Apr 02, 2014 9:41 pm
yamaha_skin.xml
(68.91 KiB) Downloaded 23 times
Hi All, i have this problem with a tour: the direction buttons works well while locally, but nothing when online, but the keyboards arrows works well ... i have made my own direction buttons using the "simple" button plugin, and i change the action into the code, i think it is ok, otherwise the buttons doesn't work even locally, no ?
For example, here is the code for the button + :
<layer name="button1"
         keep="true"
         url="%FIRSTXML%/graphics/button1/btn_plus__1_.png"
         align="bottom"
         x="-315"
         y="25"
         zorder="11"
         visible="false"
         ondown="button1ondown"
         onup="button1onup"
         handcursor="false"
         enabled="true"
         height="42"
         width="42"
           <action name="button1ondown">
set(fov_moveforce, -1);
  </action>
  <action name="button1onup">
set(fov_moveforce, 0);
  </action>
  <events name="button1events"
    onTourStart="showbutton1();"
    hidetourcontrols="hidebutton1();"
    showtourcontrols="showbutton1();"
    keep="true" />
  <action name="hidebutton1">set(layer[button1].visible, false);</action>
  <action name="showbutton1">set(layer[button1].visible, true);</action>
this code is in the file_skin.xml.
An other thing, the tour show a black screen few seconds ( 10-20 sec. ) before anything. ( and especially this one, all my others begin immediately )
I f you want to see it online, it's here : http://www.gabrielacoca.fr/wp-content/uploads/2014/02/yamaha/yamaha.html
Thank you. Gabriel.
gabriel
Likes: 14 posts
Liked in: 11 posts
Re: Direction buttons works locally but not online
by gabriel » Fri Apr 04, 2014 11:31 am
Gerald tell me that: the direction buttons described in yamaha_skin.xml file do not have any onclick or ondown events :
<layer name="button4" keep="true" url="%FIRSTXML%/graphics/button4/btn_bas.png" align="bottom" x="-180" y="25" zorder="14" visible="false" handcursor="false" enabled="false" height="42" width="42"/>
, i make the correction, and it's work fine exempt for the "home button".
But for loading, it works well: by dé-activating the mp.3, now it loads quickly.
My actual code for the button home is :
<layer name="button10"
keep="true"
url="%FIRSTXML%/graphics/button10/btn_reset.png"
align="bottom"
x="360"
y="25"
zorder="24"
visible="false"
devices="desktop"
height="42"
width="42"
ondown="lookto(get(panoview.h),get(panoview.v),get(panoview.fov),smooth(100,20,50));"
onup=""
<events name="button10events"
onTourStart="showbutton10();"
hidetourcontrols="hidebutton10();"
showtourcontrols="showbutton10();"
keep="true" />
<action name="hidebutton10">set(layer[button10].visible, false);</action>
<action name="showbutton10">set(layer[button10].visible, true);</action>
and i don't even have the mouse active when on it on my tour: http://www.gabrielacoca.fr/wp-content/uploads/2014/02/yamaha/yamaha.html
But already thank you Gérald, for the direction button, for the loading, and for your rapidity ;-)
Users browsing this forum: No registered users and 8 guests
