Screen recording software   [SOLVED] - View the solution
signmaster
Likes: 29 posts
Liked in: 24 posts
by signmaster » Tue Apr 01, 2014 12:43 pm
I have a client that wishes to play a tour from a DVD in their reception. The only way I can think of to do it would be to record the screen with screen capture software. It needs to be fairly high resolution say 1080p. In the past I have tried a couple of screen capture programs but they never produced very good results.
Any advise appreciated.
Steve
Re: Screen recording software  [SOLVED]
by AlexandreJ » Tue Apr 01, 2014 12:47 pm
The one and only to use: https://obsproject.com/
by klausesser » Tue Apr 01, 2014 1:31 pm
signmaster wrote:I have a client that wishes to play a tour from a DVD in their reception. The only way I can think of to do it would be to record the screen with screen capture software. It needs to be fairly high resolution say 1080p. In the past I have tried a couple of screen capture programs but they never produced very good results.
Hey Steve!
Are you on Mac or PC?
On Mac:
QuicktimePlayer can record the screen as movie - for free.
This one is great: http://www.syniumsoftware.com/de/screenium/
But - @Alexandre: doesn´t PTP2 provide automatic tours?
signmaster
Likes: 29 posts
Liked in: 24 posts
by signmaster » Sat Apr 05, 2014 12:06 pm
I have a PC.
Also have a copy of QuickTime player so will see if it will do the job on the PC.
Steve
Likes: 3 posts
Liked in: 215 posts
by Destiny » Sat Apr 05, 2014 12:22 pm
Steve...
If you only have a PC you cannot use the QT option... Besides, its highly limited..
You really need to go with the option that Alexandre suggested... There are other options but they can be really expensive...
by mediavets » Sat Apr 05, 2014 12:42 pm
Steve
It is difficult to create good quality video from a PTP/krpano tour.
Perhaps instead of a movie create a PTP autotour and run it from a PC to a big TV/monitor?
Or go and shoot a video.
Or create a video using still images with other software:
Muvee - http://www.muvee.com
Photo-to-Movie - http://www.lqgraphics.com/software/phototomovie.php
by klausesser » Sat Apr 05, 2014 1:43 pm
Steve
Can´t you use an auto-running tour for that purpose? Why a video?
signmaster
Likes: 29 posts
Liked in: 24 posts
by signmaster » Sun Apr 06, 2014 8:39 am
I talked to my client again and he wants to run the video from a USB drive on the TV. The TV will only run AVI files. He had a PowerPoint presentation that he said would be OK to use. I extracted the stills and audio and using Pro Show Producer made up a slide show and outputted to an AVI. I hope it is OK, works on my TV, a little cropped so may need some adjustment.
Incidentally if any one wants to extract audio and images from a PowerPoint file just rename it with a .ZIP extension and open the file with WinZip and all the individual files can be extracted.
by mediavets » Sun Apr 06, 2014 8:51 am
signmaster wrote:I talked to my client again and he wants to run the video from a USB drive on the TV. The TV will only run AVI files.
Most recent flat screen TVs have a PC (VGA) input.
Thanks for that tip.
