Start a Virtual with a map
Alex_83
by Alex_83 » Tue Apr 01, 2014 10:30 am
Hello everybody!
I'm doing a virtual tour of a little village and i would like to know:
Is it possible start a virtual tour with a map (not with a hideable map) where the user click on a hotspot and then go to the chosen scene?
Then clicking on "home" button return to the map?
Thanks... Alex
Re: Start a Virtual with a map
by mediavets » Tue Apr 01, 2014 10:49 am
Alex_83 wrote:Hello everybody!
Thanks... Alex
Yes, just use a planar projection image of the map as the first 'pano/scene' in the tour.
Alex_83
by Alex_83 » Tue Apr 01, 2014 11:00 am
I tried this, but it does a navigable image and the size of the image is zoomed...
by mediavets » Tue Apr 01, 2014 2:21 pm
Alex_83 wrote:I tried this, but it does a navigable image and the size of the image is zoomed...
It works for me.
Show me a screenshot of your first scene/map settings.
Alex_83
by Alex_83 » Tue Apr 01, 2014 2:44 pm
Thanks Mediavets for tips.
My sets for the image are the same of your. I only changed the zoom limit: max 100% & min 100% and unflagged the "limit to image resolution" so the image doesn't result zoomed;
I would like understand if there's a way to don't have a navigable image. (with planar projection)
Alex
by mediavets » Tue Apr 01, 2014 4:56 pm
Alex_83 wrote:Thanks Mediavets for tips.
Alex
I don't understand what you mean by a 'navigable image'.
Alex_83
by Alex_83 » Wed Apr 02, 2014 8:07 am
For "navigable image" I mean that image scrolls downward and upward.
I would like a still image that covers all screen area. (without scrolling up-down and left-right)
Alex
by mediavets » Wed Apr 02, 2014 8:50 am
Alex_83 wrote:For "navigable image" I mean that image scrolls downward and upward.
Alex
If the display aspect ratio varies between viewing platforms the image could not cover the entire screen in every case without distortion.
by mediavets » Wed Apr 02, 2014 8:52 am
Thanks... Alex
How many scenes are there in your tour?
Alex_83
by Alex_83 » Wed Apr 02, 2014 10:51 am
I would like to do a map like this:
http://www.museumshamilton.ca/backus/BackusMap1.html
where the user click on a scene and then returns to the map; i would not want a scrollable image like that, but an still image that cover all screen (in the browser).
Alex
by mediavets » Wed Apr 02, 2014 11:01 am
Alex_83 wrote:I would like to do a map like this:
Alex
Can you imagine that displayed map on a smartphone or a small tablet?
Do you plan to offer your tour to viewers using smartphones and tablets?
How many scenes are there in your village tour?
Alex_83
by Alex_83 » Wed Apr 02, 2014 1:37 pm
I have 12-15 scenes, and this tour will be displayed on desktops, tablets...
I'm understanding this way is difficult, so i'm thinking to open the tour with a splash screen with the map and then recall the same map with the plugin map...
Thanks mediavets for helps!
Alex
by mediavets » Wed Apr 02, 2014 2:00 pm
Alex_83 wrote:I have 12-15 scenes, and this tour will be displayed on desktops, tablets...
Alex
Yes, that sounds more practical.
I might have done it using custom thumbnails in a Thumbnails stack.
You could use a button plugin to invoke the map.
And/or use the Floorplan plugin for the map.
