CGI
georgess
CGI
by georgess » Mon Mar 31, 2014 1:22 pm
Hi all, my 1st post here. I am going to be using panopro to showcase some interior scene renders I produce on cinema 4d.
I was wondering as I can't seem to find any way on the trial or in tuts on where the files are found after I do a build.
Regards,
George
Re: CGI
by mediavets » Mon Mar 31, 2014 2:28 pm
georgess wrote:Hi all, my 1st post here. I am going to be using panopro to showcase some interior scene renders I produce on cinema 4d.
Regards,
George
georgess
Re: CGI
by georgess » Mon Mar 31, 2014 2:52 pm
Thanks mediavets,
I figured out. Now I have some questions regarding coding, I have no clue in web design etc. Which code/file do I use to embed my panotour into a website, I was planning on using iFrame which I came across today, I used another users code to test and it works. I am using WIX to build my site (that's how clueless I am hee hee)
Thanks again
Re: CGI
by mediavets » Mon Mar 31, 2014 4:44 pm
georgess wrote:Thanks mediavets,
Thanks again
Then you have your answer.
