[SOLVED] Groups and Multiple Floors   [SOLVED] - View the solution
RS360VTS
Liked in: 3 posts
by RS360VTS » Sun Mar 30, 2014 4:46 pm
Hi Guys,
I have just produced a tour of a house which has 3 floors.
Each Floor has a floor plan...
Ground Floor, 3 rooms, one floor plan
1st Floor, 5 rooms, one floor plan
2nd Floor 1 room, one floor plan
By putting the rooms into a group I can place the corresponding floor plan in the group and all works well., same for the 1st Floor... but the second floor, I cannot create a group with one room and a floor plan... the only way I could get around it is to have the room on this floor added twice. (Not ideal, but at least I can add the floor plan)
Can we have the ability to create a "group" with only one pano and one floor plan.... please?
RS360VTS
Re: Groups and Multiple Floors  [SOLVED]
by mediavets » Sun Mar 30, 2014 5:46 pm
RS360VTS wrote:Hi Guys,
RS360VTS
I have no problem creating a group containing only one pano with a group floorplan.
PTP 2.0.1 64-bit on Windows 7 Pro 64-bit.
RS360VTS
Liked in: 3 posts
by RS360VTS » Tue Apr 01, 2014 9:44 pm
Ahhh.... now I can see how its done, thanks for the "heads up"....
Simply Right hand mouse click on image, embed as a group.... bingo...
Many Thanks
RS
