This sub-forum is for users looking for a better way to solve a specific virtual tour problem, or just looking for basic instructions. Do not post any bug reports, stability issues, crash reports, etc. - use the Bug Report forum for those.
When posting, make sure that you provide as much information as possible: -Your computer specs -Link to the tour -Which version of the software you are using -How many images, what file format -What plugins you are using -Screenshots, we love those -etc..
Once the issue is solved, check the solved button on the top right corner of the post that provided you with the solution.
Make sure you post one topic per issue, so that they can be dealt with separately.
