Tour too Slow
fsimao222
Tour too Slow
by fsimao222 » Sat Mar 22, 2014 11:18 am
I'm new to virtual tours and hope someone can help me.
I've made one big virtual tour (21 (360x180) panoramas, 49 hotspots, 21 floor plan spots) with multi-resolution, incremental build, Flash and HTML5, JPG quality 12 and when I upload it to my server to see it online it is too slow to open and to change between panoramas, you even can see it rendering the panorama slowly.
I should be doing something wrong.
My panoramas size are: 3840x1920px at 300pixels/inch
here is the virtual toul to you can see.
http://servifoto.pt/Final/NT%20Gold%20Final.html
Re: Tour too Slow
by mediavets » Sat Mar 22, 2014 11:42 am
It doesn't seem that slow to me - viewing with latest Firefox on Windows 7 Pro 64-bit - and my Net connection is typically less than 3Mbps.
You could try reducing the JPEG quality to 8, 9 or 10.
Having a Little planet intro always slows initial load I think.
Switching between scenes seems acceptable to me.
Your pano images are rather small if they really are 3840x1920px.
6k x 3k would normally be considered the minimum for reasonable detail I believe, unless you are only ever going to display the pano is a small window on web page.
Re: Tour too Slow
by klausesser » Sat Mar 22, 2014 1:39 pm
fsimao222 wrote: JPG quality 12
Much too high. Use 8. I did it here: http://www.360impressions.de/Lichtturm (700MPx per pano).
fsimao222 wrote:I should be doing something wrong.
Yes: too much data-size due to JPG12.
fsimao222 wrote:My panoramas size are: 3840x1920px at 300pixels/inch
Very small pixel-size - minimizes view-quality. 300dpi is ONLY needed for offset-printig in magazines and so.
Set your APG rendering to 72dpi (default) and set JPG to max. 8 in PTP.
Re: Tour too Slow
by klausesser » Sat Mar 22, 2014 1:44 pm
mediavets wrote:6k x 3k would normally be considered the minimum for reasonable detail I believe, unless you are only ever going to display the pano is a small window on web page.
Regarding that more and more screens today have around 1920x1080px i suggest at least 10000 x 5ooopx for interactive panos being displayed in fairly good quality.
fsimao222
Re: Tour too Slow
by fsimao222 » Thu Mar 27, 2014 11:00 am
Sorry for the late reply.
Thanks for the help.
I'll test with lower quality, 72DPI and 10000x5000px.
Thanks again
shop360
Re: Tour too Slow
by shop360 » Fri Apr 04, 2014 9:36 pm
question
if im exporting in autopano should i still export at max quality (12) then set it to 8 in panotour or can i use 8 for both? or will that reduce quality further since panotour would export a lower quality pano at at quality of 8?
Re: Tour too Slow
by klausesser » Sat Apr 05, 2014 1:41 pm
shop360 wrote:question
I suggest to use TIFF for APG output and then 7 or 8 for JPG in PTP.
