[SOLVED] fixing mistakes manualy   [SOLVED] - View the solution
osmica
by osmica » Wed Mar 19, 2014 9:48 am
Hello Kolor Team,
I would like to get help fixing a mistake I've made. When I was creating the tour in PTP 2, I forgoth to rename one of my floorplans. You can see it in the screenshot. I want to rename this floor plan manualy (to avoit uploading all the tourdata again) but can't find the right file. In what file I can find this information?
Regards,
Toni
Re: fixing mistakes manualy
by Destiny » Wed Mar 19, 2014 9:52 am
Hi...
Naming you will find in your #_messages_en.xml file... Just rename and re-upload and done..
osmica
Re: fixing mistakes manualy  [SOLVED]
by osmica » Wed Mar 19, 2014 10:05 am
Destiny wrote:Hi...
I did that but it has changed only the name in description, in the dropdown floorplan manu it is still the old name. It means it is somewhere else also...
I changes the name in this command line:
<data name="en_panogroup56_floor_title"><![CDATA[Cvrčak]]></data>
by Destiny » Wed Mar 19, 2014 10:22 am
This is where your naming is done from.... You might need to clear your cache to view the name change...
<data name="en_project_floor_title"><![CDATA[Project Name]]></data>
osmica
by osmica » Wed Mar 19, 2014 10:47 am
Destiny wrote:This is where your naming is done from.... You might need to clear your cache to view the name change...
You have right, I cleared cache and now it is visible. I always forgeth about that issue:)
