[SOLVED] Start up with a quick panning
ccc23444
Liked in: 6 posts
by ccc23444 » Sun Mar 16, 2014 9:10 pm
Hi fellow panoramaphotographers
Can you tell me how I make a quick pan around in the start of loading a pano. And it goes to a place chosen by me
Best regards
Jesper
http://www.virtuelledanmark.dk
Re: Start up with a quick panning
by mediavets » Sun Mar 16, 2014 10:36 pm
ccc23444 wrote:Hi fellow panoramaphotographers
Best regards
Jesper
Check out transitions:
ccc23444
Liked in: 6 posts
by ccc23444 » Tue Mar 18, 2014 10:58 pm
Hey - thankyou
I gotta try this out
Best regards
Jesper
by klausesser » Tue Mar 18, 2014 11:31 pm
ccc23444 wrote:Hey - thankyou
Best regards
Jesper
You need to trigger the move - as Andrew showed - using a hotspot or the splashscreen.
Two examples:
triggered by a hotspot: http://www.360impressions.de/Tourk21.html
triggered by the splashscreen and then by the first hotspot: http://360impressions.de/KBogen413/
