How to display FullScreen button on iPad ?   [SOLVED] - View the solution
oreuter
by oreuter » Sun Mar 16, 2014 4:41 pm
Hello
Why does the FullScreen button disappear when then visit is seen on iPad ??
In the xml file , I tried to change the "devices" options but it doesn't work.
Very annoying when the visit is embeded in a part on the html page .
Clients become hangry at the end , because some 'old' features have been changed or are not working !!
Please help !!
Re: How to display FullScreen button on iPad ?
by mediavets » Sun Mar 16, 2014 6:27 pm
oreuter wrote:Hello
Please help !!
Because not all features are properly supported in fullscreen mode on some mobile platforms with the HTML5 viewer.
oreuter
by oreuter » Sun Mar 16, 2014 7:16 pm
Why not giving the chance to use fullscreen , if I know which feature is not supported .
My visit is so simple , no video , no text fields , nothing special .
And I'm afraid I'll loose clients ....
Re: How to display FullScreen button on iPad ?  [SOLVED]
by benji33 » Fri Mar 21, 2014 3:25 pm
You can update your code to recover the fullscreen button
See : http://www.kolor.com/forum/viewtopic.php?f=64&t=20589&hilit=fullscreen+ipad
See : http://www.kolor.com/forum/viewtopic.php?f=92&t=21783&hilit=fullscreen+ipad
But adding the button back does not necessarily mean that the mobile will be able to use it.
oreuter
by oreuter » Fri Mar 21, 2014 4:55 pm
Thanks a lot for this info .
And you are right : all mobiles do not manage Fullscreen corrrectly ...
Thanks again !
