[SOLVED] Hotspot image and www-link
markusViVi
by markusViVi » Fri Mar 14, 2014 4:49 pm
Hello together,
i have a panorama with hotspots with "display an image", easy that way. But now i like to show a www-link at the same time with the picture. I tried "display an image" and "display an description" as a second action. So the text-field and the picture is in the panorama but no text in the text-field. At the properties of the Hotpot description is the link to the Website.
An other way would be a simple button that hides and leaves with the image but i didn't find this at the "choose an action field"
Does anybody has an idea how to mange this?
many thanks
Markus
Re: Hotspot image and www-link
by mediavets » Fri Mar 14, 2014 6:09 pm
markusViVi wrote:Hello together,
many thanks
Markus
I don't understand what you are trying to do.
markusViVi
by markusViVi » Fri Mar 14, 2014 9:16 pm
So perhaps it's easier this way...
there should be a field below the image with the link "www.example.de" so someone interestet in the picture can click on the link and go to the Website. the field is there but not the link. But in the spot "see PTP-Hotspot" is the description with the link and in the style "see PTP-Style" is the second action "Display a description", so why doesn't it work out???
And a other way to manage it, would be to show an "simple button" as long as the image. But I don't know how to manage this too.
PTP-Hotspot
PTP-Style
by mediavets » Fri Mar 14, 2014 9:20 pm
Some observations:
1. I don't see a Description plugin in your Workspace?
2. I think I would prefer to do this using a Web site viewer box, which would offer a lot more possibilities for layout and styling.
markusViVi
by markusViVi » Sat Mar 15, 2014 12:12 am
So one thing i found out myself, there was no text inside the box, because it was too small, Area high 100px didn't show the text, 150px is o.k..
But there is no chance to show the discription of the hotspot only Current Projekt, Current Group or Current Panorama is available.
Any other possibility to show the discription of the hotspot??? :rolleyes:
by mediavets » Sat Mar 15, 2014 2:41 am
markusViVi wrote:The white field above the control-bar with the X.
You have to add the appropriate instances of the Description plugin - configured as you wish - to your workspace and then you will have have option.
But I would still choose to do it using a Web site viewer viewer plugin.
markusViVi
by markusViVi » Sat Mar 15, 2014 6:08 pm
Thank's, I didn' see that, sometimes the sunglasses are too dark :cool: ;).
But now it runs.
I haven't tried the programming with the web-site-viewer jet.
Do I have to progamm a website then, and save it with the panorama?
Markus
