Made tour with trial, bought license, still have watermarks
desert guy
by desert guy » Wed Mar 12, 2014 5:10 pm
I used the free trial to create a tour to see if I liked it. Despite it crashing several times I decided to buy panotour pro because I think it has more potential than the program I was using before.
Here is my problem: I spent a lot of time building a tour and I don't want to have to do it all over again but even though I entered my license info I still have watermarks all over the images in the tour that was created with the free version. I started a new one from scratch just to check and the new one had no watermarks. The images used in each pano were not made with a Kolor product and bear no watermarks.
How do I remove the watermarks?
franzkekko
Re: Made tour with trial, bought license, still have waterma
by franzkekko » Wed Mar 12, 2014 11:20 pm
Did you try to rebuild the entire project erasing your tour's folder?
Also, often panotour get some files saved as cache on browser. Have you deleted it?
Likes: 65 posts
Liked in: 170 posts
by benji33 » Thu Mar 13, 2014 9:39 am
Into build screen, check the option Rebuild all tiles. After than uncheck it and save your project.
or
Try to save project into on other directory and build again
PS : what kind of crashes ?
desert guy
by desert guy » Thu Mar 13, 2014 6:00 pm
Thanks the "rebuild all tiles" did the trick. thanks
As for the crashes I can't specifically remember what I was doing when it happened. Now that I'm invested I will log and post in the appropriate forum when it happens.
Likes: 65 posts
Liked in: 170 posts
by benji33 » Fri Mar 14, 2014 9:27 am
Thanks a lot, it helps.
