Livepano - You need an equirectangular panorama loaded
MetroRuss
by MetroRuss » Tue Mar 11, 2014 9:21 pm
I have followed the tutorial of the Restaurant Le Pano in the trial version of PTP 2.0 and got as far as importing a Live pano.
I am getting this error pop up message
"You need an equirectangular panorama loaded before importing livepano"
Have I missed something or am I doing something dumb?
Re: Livepano - You need an equirectangular panorama loaded
by klausesser » Wed Mar 12, 2014 1:49 am
MetroRuss wrote:Hello,
When you stitch a pano from pictures yiu shot in a spherical mode the final rendering is an equirectangular panorama-image.
This one you need to import into PanotourPro for making it an interactive panorama.
So you need to import the equirectangular image first and the video after that. Of course you need to shoot the video from the very same position as the spherical pano.
Shoot the video, switch from video to photo *without moving the camera at all* and start to shoot the pano-images. This way your first pano-image shows the very same as the video.
MetroRuss
by MetroRuss » Wed Mar 12, 2014 1:59 am
Thank you Klaus,
I just got back home from shooting a proper pano movie exactly as you have said.
I will post the results shortly.
MetroRuss
by MetroRuss » Wed Mar 12, 2014 4:03 am
Hi Klaus,
No luck :(
This is my work flow below.
Pictures from my 8mm samyang
stitched in apg
drag and dropped to ptp2.
saved and built, works fine from desktop as a small 3 pano tour
try to import livepano
this is the pop up error I receive.
Liked in: 227 posts
by Destiny » Wed Mar 12, 2014 4:44 am
Hi... Your panos do not have a 2:1 ratio...This is your issue...
MetroRuss
by MetroRuss » Wed Mar 12, 2014 4:53 am
Hi Destiny,
Wow, thanks!! where did you spot that? and can you please tell me where and how to remedy the problem.
My wife is calling Kolor my new girlfriend Karla. :P
Liked in: 227 posts
by Destiny » Wed Mar 12, 2014 6:45 am
Hi.. Its in your settings.. What you need to do is set to Max Projection.. You can set this as a default in your preferences so you do not have to worry about it.....
MetroRuss
by MetroRuss » Wed Mar 12, 2014 7:12 am
Thank you so much Destiny!!
We have the livepano box up woohooo!!!
Bless you!!
MetroRuss
by MetroRuss » Wed Mar 12, 2014 11:04 pm
This is my 1st try, thanks to Klaus and Destiny!!
http://virtualtournet.com/ptp2/livepano/
