Fatal Error - Parsing xml .skin - Gallery picture title
Katerina
by Katerina » Sat Mar 08, 2014 9:54 pm
Can someone please point me to the right directions? I have gallery plugin on my tour. I made some changes to the code so the pictures show the title in the gallery.
here is the modification in xml .skin file I made:
1. allowed and style the title by changing code to
<option name="title_displayed" value="true" type="bool" />
      <option name="title_font" value="Verdana" type="string" />
      <option name="title_size" value="18" type="int" />
      <option name="title_weight" value="bold" type="string" />
      <option name="title_decoration" value="normal" type="string" />
      <option name="title_color" value="f39e11" type="string" />
2. I added the text in between the brackets in title section
</settings>
   <internaldata>
      <item name="item_1" title="Beautiful hiking trails on Mt. Palomar" caption="" value="palomarcabindata/graphics/gallery/_mg_7278.jpg"/>
Everything works good on desktop devices but I'm getting Fatal Error - Parsing xml .skin on my iPhone. I figured out that if I change the title to single word with no spaces it works on both desktop and iPhone but once I adde two words with space in between it gives me the error.
Does someone know how I could fix it? The title on mobile device does not resize so it is too big, I think the best option would be to turn on the title for desktop devices only and not showing on mobile. Is it possible?
Thank you, Katerina
Katerina
Re: Fatal Error - Parsing xml .skin - Gallery picture title
by Katerina » Sun Mar 09, 2014 12:30 am
Hi, I figured it out. At least the part with the title. It was not spaces but a special character "&" which caused the problem. So the first part is solved. I'm still wondering how difficult it would be to show gallery on both type of devices - desktop and mobile but show the title on desktop only. Thank you, Katerina
by benji33 » Wed Mar 12, 2014 4:12 pm
A responsive design task is opened for all kind of devices. Will be available into a 2.X version.
