[SOLVED] onhover thumnail preview   [SOLVED] - View the solution
Octavias
by Octavias » Sat Mar 08, 2014 1:32 am
Hi everyone,
I have been searching for a way to showcase a little preview of the next panorama when you hovering over a hotspot.
I have found this thread on krpano but can't find a way to implement in the skin.xml file since its outdated maybe?
i am trying to do this in the newest Panotour Pro 2.0 version.
So to sum it up - I am looking for a code to make a onHover function display a little thumbnail that will make.
Thanks for any suggestions in advance!
Best,
- Max
Re: onhover thumnail preview  [SOLVED]
by benji33 » Wed Mar 12, 2014 2:48 pm
Can be done with krpano code.
Into your hotspot <style> tag, add onhover and onout events (if not present) and into this event add a call to an action which display the thumbnail (targetId attribute of the hotspot must be added with a reference to the target scene name) into a layer of the next scene.
Sample :
<hotspot name="spot1"
    style="myHotspotStyle"
    ath="176.666765" atv="-3.913044"
    targetId="pano2"
<style name="myHotspotStyle"
    onhover="onhover_myHotspotStyle"
    onout="onout_myHotspotStyle"
<action name="onhover_myHotspotStyle">
       <!-- get thumb url -->
   set(thumbTooltipUrl, get(scene[get(targetId)].thumburl));
   addhotspot(hotspotTooltipThumb);
   set(hotspot[hotspotTooltipThumb].url, get(thumbTooltipUrl));
   set(hotspot[hotspotTooltipThumb].ath, get(ath));
   <!-- change atv and position for thumb -->
   set(hotspot[hotspotTooltipThumb].edge, bottom);
   sub(newAtvValue, get(atv), 5);
   set(hotspot[hotspotTooltipThumb].atv, get(newAtvValue));
   <!-- define size -->
   set(hotspot[hotspotTooltipThumb].width, 200);
   set(hotspot[hotspotTooltipThumb].height, 100);
</action>
<action name="onout_myHotspotStyle">
    removehotspot(hotspotTooltipThumb);
</action>
Octavias
by Octavias » Fri Mar 14, 2014 2:19 pm
They Benj!
Thank you SO MUCH!
I am going to try to implement it and let you know if it worked. I have been searching so long for this code. thanks!
tiphaine
by tiphaine » Sat Mar 15, 2014 8:40 pm
    targetId="pano2"
I don't have that in my code. Should I add it ?
I understand it has a link with the targetid attribute: "the hotspot must be added with a reference to the target scene name" Am I right ?
I really like to add that feature but I'm kind of a noob in code :)
by benji33 » Thu Mar 20, 2014 11:31 am
Yes the targetId should be the panorama ID that you can found on the (i) icon next to the panorama name into panorama properties.
