Page 1 of 1
panotour pro 2 tours on ipad
PostPosted: Wed Mar 05, 2014 9:18 pm
by Mike Spence
I have produced a number of virtual tours which are fine when viewed on a normal PC or Mac screen. However on the iPAD 3 the image is highly pixelated and really not very good at all. Why is this and is there a fix?
Mike
Re: panotour pro 2 tours on ipad
PostPosted: Wed Mar 05, 2014 9:55 pm
by mediavets
Mike Spence wrote:I have produced a number of virtual tours which are fine when viewed on a normal PC or Mac screen. However on the iPAD 3 the image is highly pixelated and really not very good at all. Why is this and is there a fix?
Mike
What Build settings are you using?
What browser are you using to view the tour?
PostPosted: Thu Mar 06, 2014 10:06 am
by jdmulti
Using Safari and making sure all quality settings are set correctly, should work.
Check these things:
- Panorama in a good resolution? at least 2k or something
- Panorama zoom, don't make it too high. 100 zoom in and 100 zoom out is fine. Else you zoom in too much.
- Build tab > Tiles > Quality 10
Build your panorama and it should appear fine. Here I used 4k panorama images, test it this way and later tune them down a little until I have good results. Works here fine on all iPad versions, even 1
PostPosted: Wed Mar 12, 2014 4:07 pm
by benji33
Is it a multi-resolution build tour ? See your build window properties
