Splash Screen Help
Katerina
Splash Screen Help
by Katerina » Thu Feb 27, 2014 3:51 am
Hi, can someone please explain me how the splash screen in PTP works. One of the common uses of the splash screen is with large application like games, programs or large websites which need significant time to load. It normally stays on until the side is fully loaded. Is it the case of the splash screen in PTP? From the setting I'm assuming that the purpose of the splash screen is either esthetic (logo or some nice graphic) or informative ( introduction to the tour or instructions). So far I don't have any big tours where I can see delay in loading times. When is the splash screen showing? Does the tour need to be loaded first or it shows immediately after opening. Thank you, Katerina
Re: Splash Screen Help
by benji33 » Thu Feb 27, 2014 9:31 am
Splashscreen can be displayed until click and can have a delay in seconds.
But with a little bandwith the tour can be not fully loaded in background because splashscreen is not linked to preload.
blickfang
by blickfang » Thu Feb 27, 2014 11:08 am
can anybody tell me how to remove the splash screen when I am rid of it?
by mediavets » Thu Feb 27, 2014 11:12 am
blickfang wrote:can anybody tell me how to remove the splash screen when I am rid of it?
What do you mean?
blickfang
by blickfang » Thu Feb 27, 2014 11:53 am
I placed a splash screen. Now it is shown in the Tour befor loading the panos.
But now, I want no splas screen be shown at all. There is no "delete" button to remove the linked file...?!
by mediavets » Thu Feb 27, 2014 12:01 pm
blickfang wrote:I placed a splash screen. Now it is shown in the Tour befor loading the panos.
Just select and delete the filename.
blickfang
by blickfang » Thu Feb 27, 2014 12:05 pm
ok, just easy :-)
but the image file is still stored in the tourdata folder.. :-(
This has to be removed manually, even after rebuilding the tour
by mediavets » Thu Feb 27, 2014 12:46 pm
blickfang wrote:ok, just easy :-)
Check out the manage build files feature:
blickfang
by blickfang » Thu Feb 27, 2014 1:08 pm
that's it, thanks for the very quick support!
