Drag mouse!   [SOLVED] - View the solution
Eddie
Drag mouse!
by Eddie » Sat Feb 22, 2014 4:30 am
Hello! How can I generate a smoother drag with the mouse?
Thank you!
Eddie
Re: Drag mouse!
by klausesser » Sat Feb 22, 2014 1:23 pm
Eddie wrote:Hello! How can I generate a smoother drag with the mouse?
Thank you!
Eddie
Are you talking about "Drag"-mode or "Move"-mode? The "Drag" (hand-symbol) mode can´t get smoothed afaik. Fot achieving a smoother move take the "Move"-mode (arrows-symbol).
Eddie
Re: Drag mouse!
by Eddie » Sat Feb 22, 2014 10:17 pm
Hello! Thanks for answering! I'm talking about the movement mode, there is a possibility that more fluid? Sometimes stops!
Eddie
Re: Drag mouse!
by benji33 » Wed Feb 26, 2014 10:57 am
You can try to add this into your xml file and change the default values :
<control mouseaccelerate="1.0"
         mousespeed="10.0"
         mousefriction="0.8"
         mousefovchange="1.0"
         fovspeed="3.0"
         fovfriction="0.9"
         touchfriction="0.87"
Eddie
Re: Drag mouse!
by Eddie » Tue Mar 25, 2014 8:45 pm
Thanks benji33! I found an example that is done with the software Krpano!
http://flv.valloire.net/valloire/pano-hiver/index.html
My question is if I can get this fluid and smooth movement, changing the values ​​in the code you gave me? This is what I want!
Thank you!
Eddie
Eddie
Re: Drag mouse!
by Eddie » Thu Jul 03, 2014 4:08 am
Any tips? I want to get this moving! A smooth drag with the mouse!
Eddie
Likes: 14 posts
Re: Drag mouse!
by bdd » Thu Jul 03, 2014 2:14 pm
Eddie wrote:Any tips? I want to get this moving! A smooth drag with the mouse!
Eddie
The drag is the same as the one generated by panotour.
Only the speed changes a little.
Decrease the speed in the parameters Benjamin gave you.
Eddie
Re: Drag mouse!
by Eddie » Thu Jul 03, 2014 6:46 pm
You do not think that dragging Panotour, sometimes, has some small brakes? Beyond speed, I think the drag Krpano is softer, and I find it strange because they use the same system! Also going to try to fix the way Benji told me, if I can not do it, I write, it is very important to have a smooth and fluid drag!
Thank you!
Eddie
Eddie
Re: Drag mouse!
by Eddie » Thu Jul 03, 2014 8:07 pm
I would get this type drag! It was made with Panotour Pro, no?
http://www.grazia.fr/Grazia/serie-mode-la-vie-en-rose
Another thing! How I can change the cursor and put the traditional cursor (arrow you can see in the example)?
Eddie
Eddie
Re: Drag mouse!
by Eddie » Tue Sep 23, 2014 4:11 am
Hi! What is the xml file that I use to edit the values ​​of the movement and drag mouse? Where I put these codes? Sorry, I do not know anything about codes! Thanks! Sorry for my English!
mousespeed="10.0"
mousefriction="0.8"
fovspeed="3.0"
fovfriction="0.9"
Re: Drag mouse!
by benji33 » Wed Sep 24, 2014 12:37 pm
This link doesn't work : http://www.grazia.fr/Grazia/serie-mode-la-vie-en-rose (404 error)
Also to remove cursor icon look after the
<events name="cursorsEvents" onnewpano="setCursor" oncontrolmodechanged="setCursor" keep="true" />
into the YOURTOUR_core.xml file and remove it.
Eddie
Re: Drag mouse!
by Eddie » Wed Sep 24, 2014 8:52 pm
Hello, Benji! I leave you another example of what I want to achieve for the movement and drag with the mouse! It is key for me to get this fluidity in the work, so I want to know how to use and where to put these codes to modify the values ​​and try to get what I want ..
Thank you!
Eddie
Re: Drag mouse!  [SOLVED]
by benji33 » Thu Sep 25, 2014 10:26 am
Ok in fact the Flash player responds to many modes.
The default is direct wmode.
But Panotour change it to opaque wmode if you are using HTML5 plugins.
Try to edit the HTML file of the tour and remove the ,wmode: "opaque" line into the embedpano javascript function.
Or
Use the HTML5 player : YOUR_URL.html?html5=only
These tricks should remove the visible "steps" in the mouse move.
Eddie
Re: Drag mouse!
by Eddie » Thu Sep 25, 2014 7:38 pm
I am exporting in html5 (attached picture)! I want a smooth, fluid drag! View this example made ​​with Krpano! I see a smooth, fluid drag!
Please where I put these codes ??? You gave them to me! It can be a solution?
<control mouseaccelerate = "1.0"
MouseSpeed ​​= "10.0"
mousefriction = "0.8"
mousefovchange = "1.0"
fovspeed = "3.0"
fovfriction = "0.9"
touchfriction = "0.87"
A smooth drag mouse is very very important!
PS: In tablets and phones, the movement is good, smooth and soft!
Eddie
Re: Drag mouse!
by benji33 » Fri Sep 26, 2014 12:37 pm
Are you using some plugins ? If yes, which plugins ?
Do you have other elements that point hotspots in the sphere ?
Do you have an url available ?
Eddie
Re: Drag mouse!
by Eddie » Fri Sep 26, 2014 6:33 pm
Are you using some plugins? If yes, Which plugins?
Yes, gallery photos, floor plan, web video box, website box, menu, sound, description, spot video and control bar.
I leave another personal project (exported in html5) http://www.planovirtual.com.ar/test_hotel.html so you can compare with an example done with Krpano http://flv.valloire.net/valloire/pano-hiver/index.html!
It is the same type of drag? NO! Work done with Krpano has a better drag, smoother, more fluid! How is possible if the viewer is the same? I need an urgent solution!
Two more things!
1- Why to reduce the viewing angle the picture loses quality? I do not see that happening in the example Krpano!
2- You still do not answer me where to put these codes!
fovspeed = "3.0"
fovfriction = "0.9"
Eddie
Re: Drag mouse!
by benji33 » Mon Sep 29, 2014 4:13 pm
Seems that the 2 are the same.
So try to remove all HTML5 plugins (panoramaMenu, Gallery, projectionMenu, Map, Floorplan, all viewers) to see if the it's better without the plugins (some of theme use listeners).
Yes engine is the same.
Yes it's the same "drag".
The <control ... /> tag can be inserted in any XML generated file.
For FOV, small values (which correspond to a zoom in) need a high resolution image elsewhere the quality seems more blurry.
Look after the Panorama preview into the Zoom limits part.
Eddie
Re: Drag mouse!
by Eddie » Tue Sep 30, 2014 8:37 pm
Thanks Benji! I'll work on that! A Question! These controls in the preview does not appear in my interface! Why?
Eddie
Re: Drag mouse!
by mediavets » Tue Sep 30, 2014 9:43 pm
Eddie wrote:Thanks Benji! I'll work on that! A Question! These controls in the preview does not appear in my interface! Why?
Eddie
What is your graphics hardware and which platform and OS are you using?
Do you have the latest graphics drivers?
Re: Drag mouse!
by benji33 » Wed Oct 01, 2014 12:28 pm
Yes 3D preview has some issue with some graphical cards and drivers and also on some OS as MacOSX 10.9.x ... we are working for a patch.
Restart panotour solve the problem ?
