It doesnt work on mobile devices...What should I do?
Bogdan
by Bogdan » Fri Feb 21, 2014 9:25 pm
I selected mobile devices in build tour but it doesn'y work.
I uploaded my folder on my ftp server with .html file and without it.
What I do wrong?
Thanks.
Re: It doesnt work on mobile devices...What should I do?
by mediavets » Fri Feb 21, 2014 9:36 pm
Bogdan wrote:Hello,
What I do wrong?
Thanks.
Which version of PTP are you using on which OS?
Can we see :
1. a screenshot of your build settings.
2. the URL for the tour (html file) that you say doesn't work on mobile devices.
Which mobile devices with which browsers have you tried?
Bogdan
by Bogdan » Fri Feb 21, 2014 9:57 pm
I'm using PTP 2.0
HansKeesom
by HansKeesom » Fri Feb 21, 2014 10:05 pm
Bogdan wrote:I'm using PTP 2.0
and how about
"2. the URL for the tour (html file) that you say doesn't work on mobile devices.
Which mobile devices with which browsers have you tried?"
Regards, Hans Keesom
by mediavets » Fri Feb 21, 2014 10:06 pm
Why are you using a domain name as a folder name?
I'd always recommend avoiding spaces in file and folder names and also to avoid using mixed case letters in names.
What is the URL for the online tour that doesn't work?
Bogdan
by Bogdan » Fri Feb 21, 2014 10:15 pm
Do you think that this might be the problem using spaces and case letters?
My url is :http://www.tururivirtualeprahova.ro/Clinici-medicale/Clinica-stomatologica-First-Dent-Ploiesti-c3.html
Bogdan
by Bogdan » Fri Feb 21, 2014 10:16 pm
and how about
I've tried with IPAD
Bogdan
by Bogdan » Fri Feb 21, 2014 10:18 pm
by klausesser » Fri Feb 21, 2014 10:24 pm
Bogdan wrote:Do you think that this might be the problem using spaces and case letters?
No - you "filled" the spaces with "-" . . so there is no space between the letters.
It works on the iPad simulation in Safari.
Bogdan
by Bogdan » Fri Feb 21, 2014 10:48 pm
I have tried without spaces filled with "-" and it's still not working
It ask me for Adobe Flash Player
by mediavets » Fri Feb 21, 2014 11:12 pm
You said you uploaded the folder created when you build the tour.
What is the URL of the HTML file in that folder?
When you placed the tour on your web page you should have used an iframe referencing that HTML file - I can't see that you did when looking at the page source.
by klausesser » Sat Feb 22, 2014 12:55 pm
I tried it on my iPhone too: works . . . I suggest you check the build settings again carefuly and better use Flash AND html for building the tour . . .
As long as there is no empty space at all between words everything is ok.
Likes: 82 posts
Liked in: 184 posts
by benji33 » Thu Feb 27, 2014 9:07 am
What is your mobile device ?
