I need Help with the presets!
Frenchev
Liked in: 3 posts
by Frenchev » Thu Feb 20, 2014 9:56 pm
I try to build a tour with presets which I made with PTP RC2. Now I have the final version PTP2.0 and the program crashes every time when I try to use the presets. Am I doing something wrong?
Thanks!
Emiliyan
Liked in: 226 posts
Re: I need Help with the presets!
by Destiny » Thu Feb 20, 2014 10:33 pm
Hi... Are you using any HTML custom templates...??
Destiny....
Frenchev
Liked in: 3 posts
by Frenchev » Fri Feb 21, 2014 8:28 am
No. It crash even when I use the Kolor default presets.
Likes: 13 posts
Liked in: 112 posts
by bdd » Fri Feb 21, 2014 1:55 pm
Frenchev wrote:I try to build a tour with presets which I made with PTP RC2. Now I have the final version PTP2.0 and the program crashes every time when I try to use the presets. Am I doing something wrong?
Thanks!
Emiliyan
Did you have some spots in your tour before changing the preset ?
We found a bug (thanks to the crash reports done by some users) occuring when you build a tour after a change of a preset.
Spots are not anymore associated to a spot style, they loose their action.
This bug will be fixed in next fix release.
Waiting for this release, you have to re-select the spot style for each spot, after you change the preset.
