Values ​​zoom!
Eddie
Values ​​zoom!
by Eddie » Thu Feb 20, 2014 5:21 am
Hello! I want to change the starting value of the zoom and from that I will not use the zoom out, but I will use the zoom in ... How I can do?
Thank you!
Eddie
Re: Values ​​zoom!
by mediavets » Thu Feb 20, 2014 11:13 am
Eddie wrote:Hello! I want to change the starting value of the zoom and from that I will not use the zoom out, but I will use the zoom in ... How I can do?
Thank you!
Eddie
You can set the default view, and mi/max zoom levels, in the Preview/3D editor in the Panorama properties panel.
Eddie
Re: Values ​​zoom!
by Eddie » Thu Feb 20, 2014 8:33 pm
Thank you! I already made the setting of the default view! What values ​​should I use to remove zoom out, do not want any zoom out ..
Eddie
Eddie
Re: Values ​​zoom!
by Eddie » Sat Feb 22, 2014 10:20 pm
Someone who knows about this?
Thanks!
Re: Values ​​zoom!
by mediavets » Sat Feb 22, 2014 10:38 pm
Eddie wrote:Thank you! I already made the setting of the default view! What values ​​should I use to remove zoom out, do not want any zoom out ..
Eddie
Then set the zoom levels accordingly in the Panorama properties
