Descriptive Hotspots With Image
franzkekko
by franzkekko » Thu Feb 20, 2014 12:48 am
Hi all,
I'm working on a vTour in which I have to put some hotspost where appears a description below an image.
I think it should be done as PDF box or HTML...but if the way is javascript, I don't know how to do it =(
My problem is that I'm able to open a website box or a pdf box, but it's just a plugin and not a hotspot, so this function is available only on the template and not exploring the tour (I need about 5 description's spots each pano).
I hope someone can help me :)
Have a nice day.
Re: Descriptive Hotspots With Image
by mediavets » Thu Feb 20, 2014 10:37 am
franzkekko wrote:Hi all,
Have a nice day.
I think you want to be able to click on a hotspot and this displays an image with a description beneath it? Is that correct?
If so, then I think it would be easiest to incorporate the description in the image.
franzkekko
by franzkekko » Thu Feb 20, 2014 10:45 am
Yes it is.... And it's the solution I thought, not too flexible, but quite simple :)
Thanks mediavets ;)
by mediavets » Thu Feb 20, 2014 10:47 am
franzkekko wrote:Yes it is.... And it's the solution I thought, not too flexible, but quite simple :)
Thanks mediavets ;)
Simple and you have full control over styling.
