Panotour Pro 2 Map Plugin is Not Working
nirmiksoni
by nirmiksoni » Wed Feb 19, 2014 2:00 pm
Dear All Reader,
Please check map Plugin panotour pro 2 Win Version. It's Not showing floor plan in panorama.
can guide me About Same Problem
pgielen
Liked in: 5 posts
Re: Panotour Pro 2 Map Plugin is Not Working
by pgielen » Wed Feb 19, 2014 2:08 pm
Indeed, I have the same problem. The floor plan plugin does nothing in the final tour. Which doesn't surprise me since the plugin settings don't even allow me to add a floor plan image. Or am I missing something?
Pierre
by mediavets » Wed Feb 19, 2014 2:09 pm
nirmiksoni wrote:Dear All Reader,
The Panotour maps plugin is not eeh same thing as the Floorplan plugin.
Perhaps you have confused the two plugins?
In PTP 1.8 what is now the PTP 2.x Floorplan plugin was named the Map extra.
by mediavets » Wed Feb 19, 2014 2:12 pm
pgielen wrote:Indeed, I have the same problem. The floor plan plugin does nothing in the final tour. Which doesn't surprise me since the plugin settings don't even allow me to add a floor plan image. Or am I missing something?
Pierre
You need to specify the Floorplan graphics in the Project and/or Group properties panels in the Tour section.
You can specify a Floorplan graphic for the Project as a whole and/or each Group.
pgielen
Liked in: 5 posts
by pgielen » Wed Feb 19, 2014 3:42 pm
Oops. It works now!
