Autotour with auto images
netline
by netline » Wed Feb 19, 2014 9:54 am
Good Day All,
I have a unique obstacle, more and more of my clients are asking if they can use the autotour function and with PTP 2 it is an easy thing to do but now I have a client wanting to have an autotour with images coming up at specific times kind of like a Powerpoint presentation. The reason behind this is that when the relevant marketing manager is doing a presentation infront of a group of people they would like to keep the flow and not have to turn and push buttons.
I look forward to some creative solutions!
Likes: 3 posts
Liked in: 224 posts
Re: Autotour with auto images
by Destiny » Wed Feb 19, 2014 10:59 am
emm.. I think the only way to achieve this would be to put the Tour into Powerpoint, which I read it is possible.... Then use the Powerpoint features as you need them for the timed pop-ups.. As for doing this in PTP, not possible.. ....
Destiny....
by mediavets » Wed Feb 19, 2014 11:29 am
netline wrote:Good Day All,
Why would he/she have to turn?
Does your client want to the scenes to change strictly according to a preset time interval or also want manual override?
Is it intended to use autorotation?
Likes: 60 posts
Liked in: 169 posts
by benji33 » Wed Feb 19, 2014 11:51 am
No timeline editor. But I add it as feature request.
netline
by netline » Wed Feb 19, 2014 11:54 am
Great this would be a great feature.
When having to stop the tour to show an image they would have to click pause and then show a pic.
Also Manual Overide
Yes
by mediavets » Wed Feb 19, 2014 11:56 am
benji33 wrote:No timeline editor. But I add it as feature request.
At last an acknowledgment that this is a requirement - but it needs more features too.
by mediavets » Wed Feb 19, 2014 12:09 pm
Also Manual Overide
Yes
Did you consider the Previous/Next Strips plugin - see screenshot.
If your presenter was to use a touchscreen device, a tablet PC mounted on a lectern for example, to drive his/her data projector, then it would be very easy to move forwards and backwards through the scenes, changing scenes whenever it suited his/her delivery, and there would be no need to turn around away from the audience.
You could also have a control bar which starts closed to provide full manual override controls if required.
netline
by netline » Wed Feb 19, 2014 12:13 pm
If your presenter was to use a touchscreen device (mounted on a lectern for example), to drive his/her data projector, then it would be very easy to move forwards and backwards through the scenes, changing scenes whenever it suited his/her delivery, and there would be no need to turn around away from the audience.
Thank you Media Vets, it is a good idea however the owner of the property is over 70 years old and wants this process to be as automated as possible.
by mediavets » Wed Feb 19, 2014 12:27 pm
I think this form of manual control over scene chnage - prev/next strips on left and right edges of the tour display - would be superior to having pre-timed autochange of scenes, because that would demand that the presenter always managed to time his/her delivery to the second otherwise it could all go out of sync.
I'm 65 and I hope I'll still be able to touch a strip at either edge of the screen when I'm over 70.
If you can accept a fixed time interval; between scene changes then that can be specified now of course via the GUI.
by mediavets » Wed Feb 19, 2014 1:02 pm
Another approach, which allows different timings for automatic scene changes for each scene.
360panogallery can do this:
http://ww2.360panotours.com/index.html
But it needs inputs to be SWF files created with Pano2VR.
However Pano2VR and 360panogallery are relatively inexpensive so you might consider this approach.
