HTML5 and Partial spherical panoramas
tiphaine
by tiphaine » Tue Feb 18, 2014 12:25 am
I guys !
I'd like to make a tour in HTML 5 with partial spherical panoramas. I've learned that the "viewing would be limited to the resolution of the generated cube faces" (too low for my purpose) unless I "force (my) panorama as a full 360°x180° spherical panorama in Autopano" (source here: http://www.autopano.net/wiki-en/action/view/Panotour_Pro_2_-_FAQ#What_is_NOT_supported_by_HTML5_player_.3F).
Problem is:
All my panos are already achieved in .psd and I can't find a way to re-put them in autopano (the app doesn't react when i drag and drop a single .psd).
Anyone have and idea to help me not to redo all my panos ??
tiphaine
Re: HTML5 and Partial spherical panoramas
by tiphaine » Tue Feb 18, 2014 12:41 am
Let say I find a rapid way to re-put my pano into autopano (I split it in photoshop and save 2 .tif)...
Anyway, how do "I force your panorama as a full 360°x180° spherical panorama in Autopano" as the documentation invite me to do ?
Any tuts welcome ! :D
Likes: 11 posts
Liked in: 96 posts
by bdd » Tue Feb 18, 2014 9:55 am
tiphaine wrote:Let say I find a rapid way to re-put my pano into autopano (I split it in photoshop and save 2 .tif)...
Just click on the "360x180" button in the crop tool :
http://www.autopano.net/wiki-en/action/view/Autopano_Giga_-_Panorama_Editor_-_Geometry_Correction#Crop
by mediavets » Tue Feb 18, 2014 10:05 am
With APP/APG you will I think have to redo the stitch.
You may be able to do it without restitching in PTGui
tiphaine
by tiphaine » Tue Feb 18, 2014 3:19 pm
First, I'd like to thank both of you, Gérald and Mediavets. I've found our advices very interesting.
But now my problem has change !
I found that making a partial pano into a fake sphere reduce the quality of the final result. My pano has less resolution, I come faster to 100% and my purpose is to give the best viewable quality to my pictures. :(
I understand it's an APG issue I have, maybe I should change the place of this topic ?
left: the sphere pano @ 2%
right: the partial pano @ 2%
left: the sphere pano @ 100%
right: the partial pano @ 100%
by mediavets » Tue Feb 18, 2014 3:48 pm
tiphaine wrote:First, I'd like to thank both of you, Gérald and Mediavets. I've found our advices very interesting.
PTP doesn't support HTML5 multi-resolution output for pano images which use a spherical projection but have a panoFOV of less than 360x180.
You can try forcing a 360x180 panoFOV when stitching your pano and then using the crop tool in the Hotspot editor in PTP 2.0.
But it may not work well, because it will generate a lot of unused tiles.
Try it and see.
tiphaine
by tiphaine » Tue Feb 18, 2014 4:00 pm
Ok, After many tests... I'm finally going to do this with flash.
Thanks again for fasts and clears answers !
by mediavets » Tue Feb 18, 2014 4:08 pm
tiphaine wrote:Ok, After many tests... I'm finally going to do this with flash.
If you go for Flash-onlty then it won't be veiable on any mobile platforms.
If you choose multi-res for both Flash and HTML5 and output for all types of platform then those with Flash-enabled platforms will see a higher res. but those with mobile platforms will still see something.
Or, you could offer those with mobile platforms an alternative viewing option using say, Zoomify, or Gigapan.com, or GigaPX2pano:
http://www.bigmike.it/gigapx2pano/
