snow effect   [SOLVED] - View the solution
viewmaster
by viewmaster » Sun Feb 16, 2014 5:56 pm
I'm using the snow effect in a virtual tour that has 5 panoramas. One of them is an interior space which means I don't want the effect there. How can I have the snow effect only in 4 out of 5 panoramas in the same virtual tour?
Thank you
Thomas
Liked in: 227 posts
Re: snow effect
by Destiny » Sun Feb 16, 2014 9:36 pm
Well... Yes.!. Its mystery as to how it could actually snow indoors... it can rain too... :rolleyes:
Sorry to say, not possible via the GUI... You will need to hand code it..
viewmaster
Re: snow effect
by viewmaster » Mon Feb 17, 2014 6:35 pm
Destiny wrote:Well... Yes.!. Its mystery as to how it could actually snow indoors... it can rain too... :rolleyes:
It is a mystery when it snows indoors :)
Unfortunately my hand coding is very basic... =(
Thanx anyway
Thomas
Liked in: 227 posts
Re: snow effect
by Destiny » Mon Feb 17, 2014 6:41 pm
I will play with the code and if it works I will ask you to send me your code to edit for you...
viewmaster
Re: snow effect
by viewmaster » Tue Feb 18, 2014 4:01 pm
Destiny wrote:I will play with the code and if it works I will ask you to send me your code to edit for you...
Thank you Destiny :)
Liked in: 227 posts
Re: snow effect
by Destiny » Wed Feb 19, 2014 1:23 am
Hi.. Ok, that's doable.. =D
http://www.destinyvirtualtours.com/PTPV ... /Snow.html
Its an easy fix but you need to edit your #skin.xml code by removing the show plugin and in your #.xml you need past it in like this.. Set the keep to false..
That should work for you..
<preview url="%FIRSTXML%/grey_10/preview.jpg" type="CUBESTRIP" striporder="FRBLUD"/>
<!-- Snow -->
<plugin name="snowDestiny"
url="%FIRSTXML%/graphics/snow.swf"
alturl="%FIRSTXML%/graphics/snow.js"
keep="false"
zorder="3"
wind="5.0"
<image type="CUBE" multires="true" baseindex="0" tilesize="512">
<level tiledimagewidth="512" tiledimageheight="512">
<front url="grey_10/0/0/%v_%u.jpg"/>
<right url="grey_10/1/0/%v_%u.jpg"/>
<back url="grey_10/2/0/%v_%u.jpg"/>
<left url="grey_10/3/0/%v_%u.jpg"/>
<up url="grey_10/4/0/%v_%u.jpg"/>
<down url="grey_10/5/0/%v_%u.jpg"/>
</level>
</image>
viewmaster
Re: snow effect
by viewmaster » Wed Feb 19, 2014 6:19 pm
Hi Destiny,
a million thanks for your help! It works perfect!!!! :)
Thomas
Liked in: 227 posts
Re: snow effect
by Destiny » Thu Feb 20, 2014 10:32 am
Thats ok.. =D
...but I find the snow effect a bit limited.. When I view it on my Samsung Note, its not great at all... Infact it almost stops... This test here uses JS to drive the snow... It works beautifully on my Samsung Note... Its is even dymanic, you can move it a bit if you move your mouse over it... I tried to get it to work within a Tour but no luck yet.. The best I can do is to place it into a window... Might be a good outside intro.. but not a VR pano... =(
http://www.destinyvirtualtours.com/PTPV ... Ssnow.html
viewmaster
Re: snow effect
by viewmaster » Sat Feb 22, 2014 11:09 am
It's very impressive!!! Especially that you can move when you move the mouse! :)
On the ipad the snow effect works fine.
Thomas
