View Build Tour Not Working
three60mktg
by three60mktg » Wed Feb 12, 2014 8:10 am
hi,
just download the demo version.
using Mac Version 10.8.5
Download the panotour Pro 2.0 version.
Just started using and i encounter and 1st error.
after i added in the panos, save and build. When i try to click the view last build tour . it cannot work
it opens up the browser: and have the following input: http://www.localhost.com:31415/index.html
how do make it view ??
thanks
Likes: 3 posts
Liked in: 225 posts
Re: View Build Tour Not Working
by Destiny » Wed Feb 12, 2014 8:22 am
Hi... No one will ever be able to view that since it a local host.. You need to upload your html page and the entire Tour build folder to a web sever..
Destiny....
three60mktg
by three60mktg » Wed Feb 12, 2014 8:30 am
hi,
u mean when we click the green play button, it will not show anything ?
i need to upload to my web sever before i can see it straight??
Likes: 3 posts
Liked in: 225 posts
by Destiny » Wed Feb 12, 2014 8:47 am
Hi.. Well the Green button is the PTP V2 local server so it should work..
You will need to dot point your steps and processes and we will be able to see what you are doing wrong..
The first thing even with no plugins is to add your pano/s either as full pano image/s or cube faces.. Even if you did not add anything into PTP it will still show a default white grid so something you are doing is wrong..
by mediavets » Wed Feb 12, 2014 10:24 am
three60mktg wrote:hi,
Th green button should work.
What browser on which OS are you using?
three60mktg
by three60mktg » Sat Feb 15, 2014 12:20 pm
hi i am using mac 10.8.5
using firefox. Version.26.0
the funny thing is when i click the green button, it auto point to "localhost:31415/index.html"
i cannot find the place to edit where this point to.
any advice?
by mediavets » Sat Feb 15, 2014 12:26 pm
three60mktg wrote:hi i am using mac 10.8.5
any advice?
Why do you believe that URL is incorrect?
When you use that button the tour is delivered via a built-in lightweight web server - hence the URL.
The tour must be loaded in PTP and you must have performed a build before this will work.
three60mktg
by three60mktg » Sat Feb 15, 2014 2:17 pm
"The tour must be loaded in PTP and you must have performed a build before this will work."
What is PTP?
i loaded the tour into ftp into my own webserver.
Yes, i had already performed a build many times.
by mediavets » Sat Feb 15, 2014 2:42 pm
three60mktg wrote:"The tour must be loaded in PTP and you must have performed a build before this will work."
What is PTP?[/quote
Panotour Pro.
The green button is just to allow you to view the tour from local disk, not for viewing online tours.
The URL to view the tour online will be domain-name/folder-name/filename.html
Likes: 60 posts
Liked in: 169 posts
by benji33 » Mon Feb 17, 2014 3:39 pm
three60mktg wrote:it opens up the browser: and have the following input: http://www.localhost.com:31415/index.html
It opens on http://www.localhost.com:31415/index.html or on http://localhost.com:31415/index.html ?
three60mktg
by three60mktg » Tue Feb 18, 2014 7:52 am
Likes: 60 posts
Liked in: 169 posts
by benji33 » Tue Feb 18, 2014 9:23 am
And what happens with if you fill it manually : http://localhost.com:31415/index.html after green button press ?
three60mktg
by three60mktg » Wed Feb 19, 2014 3:41 am
nothing happen.
Likes: 60 posts
Liked in: 169 posts
by benji33 » Wed Feb 19, 2014 11:06 am
Sorry the url is http://localhost:31415/index.html. What happens with this ? You press the green button and enter this url manually after.
three60mktg
by three60mktg » Mon Mar 03, 2014 5:15 am
hi benji33 ,
i saw from your tutorial, that after we save, build and press the green button, we can see the actual tour in browser. But over my side. i dont see anything. In the browsers, it leads me o that url. which is non-existance.
by mediavets » Mon Mar 03, 2014 9:23 am
three60mktg wrote:hi benji33 ,
PTP must be running and the tour loaded and a build performed prior to using the green button.
