Map Point Radar
vaslag
Map Point Radar
by vaslag » Tue Feb 11, 2014 8:36 pm
I'm in a project, that uses multi floor map. There are several floor maps and a section of the building (one section with correspondent floor highlighted per floor), to allow change floors and situate visitor. I need radars in the floor plans, but not in section map.
Exists any way to choose showing or not showing radars for a specific point?
Re: Map Point Radar
by mediavets » Tue Feb 11, 2014 9:11 pm
vaslag wrote:I'm in a project, that uses multi floor map. There are several floor maps and a section of the building (one section with correspondent floor highlighted per floor), to allow change floors and situate visitor. I need radars in the floor plans, but not in section map.
Not via the GUI.
vaslag
Re: Map Point Radar
by vaslag » Tue Feb 11, 2014 9:27 pm
Can you give me some orientation to help me investigate?
Re: Map Point Radar
by benji33 » Mon Feb 17, 2014 2:34 pm
Code is global and can't be called on some points only.
vaslag
Re: Map Point Radar
by vaslag » Mon Feb 17, 2014 2:40 pm
Thanks for you response,
I solved the problem... The map points on the "section" plan, are linked to a group of secenes, and the map point for "floors" are linked to a scene each. This way, no radar appears on section points.
Re: Map Point Radar
by mediavets » Mon Feb 17, 2014 2:47 pm
vaslag wrote:Thanks for you response,
I don't understand - do you have an example?
