Is it possible to have a pop-up photo or text with links?
Redmar
by Redmar » Wed Feb 05, 2014 1:26 pm
We can't seem to find a way in Panotour Pro 2 RC2 to add a link to a photo hotspot, gallery or text box.
What we want:
1. Visitor clicks on a hotspot
2. Pop-up opens with photo/video and text.
3. Visitor can click on a link or text in the pop-up to open a website in a new browser window
Seems so simple; but is it possible?
Re: Is it possible to have a pop-up photo or text with links
by mediavets » Wed Feb 05, 2014 3:07 pm
Redmar wrote:Hi,
What we want:
Yes, you would need to use a Web site box viewer plugin to create the pop-up with photo/video and text and the link to a new browser window.
Likes: 82 posts
Liked in: 183 posts
by benji33 » Thu Feb 06, 2014 11:22 am
Yes Mediavets has the solution with your own webpage.
At this time, Description plugin doesn't display image, and Gallery plugin doesn't offer text support.
Other possible solution : edit the yourtour_skin.xml file of your tour and into the gallery plugin code look after the internaldata tag. Attribute caption can be used to add text but probably not a link (no tests have been done on this point).
Redmar
by Redmar » Wed Feb 19, 2014 1:27 pm
We'll go for the website box for now. It would be a great feature for new versions. Thanks!
