Help - FATAL ERROR - xml parsing failed!
Frenchev
Liked in: 3 posts
by Frenchev » Thu Jan 30, 2014 8:25 pm
I build a tour. On the PC everything is fine but on Android comes "FATAL ERROR - /index.xml - xml parsing failed!"
This is the tour: http://www.pan360.eu/panoramas/hotels/international/tour/index.html
How can I solve this?
Thanks!
Emiliyan
Re: Help - FATAL ERROR - xml parsing failed!
by mediavets » Thu Jan 30, 2014 8:45 pm
Frenchev wrote:I build a tour. On the PC everything is fine but on Android comes "FATAL ERROR - /index.xml - xml parsing failed!"
Thanks!
Emiliyan
Which Android device, what version of the Android OS and which browser?
Frenchev
Liked in: 3 posts
by Frenchev » Thu Jan 30, 2014 8:55 pm
Android 4.2.2 on HTC One SV, on Nexus 5 on all browsers.
by mediavets » Thu Jan 30, 2014 9:24 pm
Frenchev wrote:Android 4.2.2 on HTC One SV, on Nexus 5 on all browsers.
Perhaps you can locate a fix the XML error.
by mediavets » Thu Jan 30, 2014 9:28 pm
Another clue.
It doesn't like the double hyphen in the comment generated by PTP.
Perhaps you need to change the name it refers to?
Frenchev
Liked in: 3 posts
by Frenchev » Fri Jan 31, 2014 9:15 am
I found it. It was my mistake an bug in the program. One of the groups was called "I-SPA". I didn't see that there were two "-" in the name - "I--SPA". I just removed them and now is fine.
So be careful when you use this signs in the name of panoramas or groups.
Likes: 60 posts
Liked in: 169 posts
by benji33 » Fri Jan 31, 2014 9:27 am
Yes a patch exist for the next release to avoid this problem.
You can also remove comments into the build window options.
