Bughunting. 99 x 360 and 2 flat images. "XML parsing failed"
John360
by John360 » Wed Jan 15, 2014 11:50 am
Im publishing a tour with 99 360`s and 2 flat images.
The solution has cropped nadir for flash, hotspot links between images, control bar and the old default panorama menu. It works well as flash but it does not work as HTML5. With 101 nodes all with hotspot settings its hard to hunt down the error so I would be happy to receive suggestions on what may be the cause.
Error message when using ?html5=always is:
Fatal error....xml parsing failed
Re: Bughunting. 99 x 360 and 2 flat images. "XML parsing fai
by benji33 » Wed Jan 15, 2014 11:59 am
John360 wrote:Im publishing a tour with 99 360`s and 2 flat images.
on which xml file ? tourtour_skin.xml ? Can you send here or in private message the corrupted file for verification. thanks.
John360
by John360 » Wed Jan 15, 2014 12:18 pm
I will be happy to. Just a moment.
by benji33 » Wed Jan 15, 2014 2:20 pm
Ok due to parsing of an XML comment. Uncheck "Insert comments..." into the Build screen, Protection part.
Bug has been opened.
